Einleitung
These steps must be followed before replacing any internal parts in the HP Deskjet 1000 J110a. Don't forget to keep track of the screws.
Was du brauchst
Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Very intuitive, good instructions. Highly recommended.
Thank you very much for the instructions on removing the cover to the HP 1200 Deskjet. It allowed me to removed a part that fell into the printer and prevented the paper from advancing.
