Einleitung
The ink carriage motor is responsible for moving the ink cartridge around for it to disperse ink. Follow these steps carefully and it should be an easy fix.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped). Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped). Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
    • Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
  2. In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer. In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer. In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
    • In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
  3. With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
    • With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Locate and remove the two flat ribbon connectors which connect the circuit board to the other printer components. Remove each connector using tweezers if it is too difficult to remove them by hand. Remove each connector using tweezers if it is too difficult to remove them by hand.
    • Locate and remove the two flat ribbon connectors which connect the circuit board to the other printer components.
    • Remove each connector using tweezers if it is too difficult to remove them by hand.
  6. Locate and remove the three multicolored wire connectors which connect the circuit board to the other printer components. Remove each connector by hand, as shown. You can use tweezers if it is too difficult to remove them by hand.
    • Locate and remove the three multicolored wire connectors which connect the circuit board to the other printer components.
    • Remove each connector by hand, as shown. You can use tweezers if it is too difficult to remove them by hand.
  7. Remove the top two 13mm screws using a screwdriver with the T10 torx bit. Remove the bottom 9mm screw using a screwdriver with the T10 torx bit, and remove the plug port circuit board. Remove the bottom 9mm screw using a screwdriver with the T10 torx bit, and remove the plug port circuit board.
    • Remove the top two 13mm screws using a screwdriver with the T10 torx bit.
    • Remove the bottom 9mm screw using a screwdriver with the T10 torx bit, and remove the plug port circuit board.
  8. Remove the two 13mm screws with the screwdriver and a T10 torx bit. Slide the ink dispenser to the center in order to reach the screws.
    • Remove the two 13mm screws with the screwdriver and a T10 torx bit.
    • Slide the ink dispenser to the center in order to reach the screws.
    • Remove the one 9mm screw with the screwdriver and a T10 torx bit.
  9. Lift the entire ink dispenser assembly out of the printer.
    • Lift the entire ink dispenser assembly out of the printer.
    • Ignore the following step if you are replacing the paper roller motor instead of the ink carriage motor.
  10. Remove the two 5mm screws which hold motor in place. Remove the belt from the round motor gear, then remove the ink carriage motor. Be careful not to allow pulley on right side of belt to fall out and become lost. It will remain in place if the assembly is handled gently.
    • Remove the two 5mm screws which hold motor in place.
    • Remove the belt from the round motor gear, then remove the ink carriage motor.
    • Be careful not to allow pulley on right side of belt to fall out and become lost. It will remain in place if the assembly is handled gently.
    • Ignore these instructions if you are replacing the paper roller motor instead of the ink carriage motor.
Abschluss
Chris Perez
196 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S5-G3, Passmore Spring 2018 Mitglied von USF Tampa, Team S5-G3, Passmore Spring 2018
USFT-PASSMORE-S18S5G3
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 22
Insgesamt: 231
