Zum Hauptinhalt wechseln
HP Deskjet 2624 Ink Cartridges Replacement
  1. HP Deskjet 2624 Ink Cartridges Replacement, Ink Cartridges: Schritt 1, Bild 1 von 1
    • Unplug all of the cords from the printer and put paper into the input tray.
  2. HP Deskjet 2624 Ink Cartridges Replacement: Schritt 2, Bild 1 von 3 HP Deskjet 2624 Ink Cartridges Replacement: Schritt 2, Bild 2 von 3 HP Deskjet 2624 Ink Cartridges Replacement: Schritt 2, Bild 3 von 3
    • Lower the output tray and the ink cartridge access door.
    • Lightly press forward on the cartridge to release it and then pull the cartridge straight out.
    • The slot on the left is the tri-color cartridge while the black cartridge is on the right.
  3. HP Deskjet 2624 Ink Cartridges Replacement: Schritt 3, Bild 1 von 3 HP Deskjet 2624 Ink Cartridges Replacement: Schritt 3, Bild 2 von 3 HP Deskjet 2624 Ink Cartridges Replacement: Schritt 3, Bild 3 von 3
    • On the new cartridge, pull the colored tab to remove the plastic.
    • Hold the replacement with the nozzles toward the printer and insert it at an upward angle.
    • Push the cartridge forward until it snaps into place.
    • Repeat steps two and three if necessary.
Abschluss
After completing this guide, don’t forget to plug in your HP Deskjet 2624 .
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 24
Insgesamt: 1,147
