Zum Hauptinhalt wechseln
HP Deskjet 2624 Motherboard Replacement
Was du brauchst
  1. HP Deskjet 2624 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Unplug all cords from the printer and remove the paper.
  2. HP Deskjet 2624 Motherboard Replacement: Schritt 2, Bild 1 von 2 HP Deskjet 2624 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Using the Torx T5 screwdriver, remove the four screws connecting the scanner bed module to the printer base.
  3. HP Deskjet 2624 Motherboard Replacement: Schritt 3, Bild 1 von 2 HP Deskjet 2624 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Gently lift the scanner bed module slightly off of the printer base. Be sure to carefully unplug the ribbon cables before fully removing the scanner bed.
    • Unplug the ribbon cables by pulling them gently straight out of their plugs.
  4. HP Deskjet 2624 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the cables connected to the motherboard by gently pulling them straight out. Do not unplug the cables by pulling on the wires.
    • Unplug the last two ribbons connected to the motherboard by gently pulling them straight out.
    • Be sure to take note of where all plugs and ribbons are connected to the motherboard.
    • Remove the motherboard from the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 475
