Einleitung
In this guide, we're going to help you clean your device so that it keeps on printing the documents you need and the photos you love! Specifically, we'll refer you to the General Disassembly Guide for this device so you can access the components which you're learning to maintain!
Was du brauchst
Turn the printer around so the back of it is facing you.
Use two fingers to simultaneously press the two grooves on the back of the printer down and in.
Pull the panel off of the printer using your hands.
Use a screwdriver to remove each screw.
Use both hands to pull out and remove the rear support structure.
Carefully remove the shell that encases the internal parts of your printer.
Use both hands to gently remove the shell from the base of the printer. Place your hands at the corners and firmly lift the shell until it pops off of the base. Do not pry or bend the shell.
Use a screwdriver to remove the screws from the printer carriage assembly (the piece of machinery that moves the ink back and forth).
Remove the screws from the green, plastic motherboard. Gently loosen the motherboard from its base, but don't completely pull it out - there are wires attached to it.
Use a screwdriver to remove the screws from the motor carriage. The motor carriage holds the motor and allows your printer to print.
Should you need to replace the motor, use a screwdriver to remove the screws from the motor housing.
Use your fingers to remove the motor from the housing. Next, replace the motor with a new one.
Now that you've completed steps 1 through 6, your printer should look like the one in the photograph.
To complete the disassembly, use a screwdriver to remove any remaining screws.
To clean the exterior of the device, generally a soft, moist cloth can be used to wipe away any dust, smudges, or other granules that may have collected on the device. Be careful not to dampen the cloth too much, as excessive water (or other liquids) slipping into the interior could damage the device.
One you are able to access the interior (with the help of the General Disassembly Guide, there may be an amount of ink residue that builds up inside the device, so be thorough when sterilizing your printer.
However, regarding general maintenance, the ink cartridges and carriage are your main concern, as most other residue is normal build-up for this device.
When cleaning your printer, do not use alcohol or other platen cleaners, as this could severely damage your device.
To maintain the ink cartridges, you simply wipe them down with a soft, clean cloth.
However, if you find the dried ink stains disconcerting, know that they are character of a healthy, functioning device. You can still wipe them off, but be cautious not to rub too hard- you risk denting or otherwise damaging the machine.
