Zum Hauptinhalt wechseln
HP Deskjet D1660 Encoder Strip Replacement
Was du brauchst
  1. HP Deskjet D1660 Encoder Strip Replacement, Encoder Strip: Schritt 1, Bild 1 von 1
    • Remove the back two 14.0 mm Torx #10 screws.
  2. HP Deskjet D1660 Encoder Strip Replacement: Schritt 2, Bild 1 von 1
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
  3. HP Deskjet D1660 Encoder Strip Replacement: Schritt 3, Bild 1 von 1
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
  4. HP Deskjet D1660 Encoder Strip Replacement: Schritt 4, Bild 1 von 3 HP Deskjet D1660 Encoder Strip Replacement: Schritt 4, Bild 2 von 3 HP Deskjet D1660 Encoder Strip Replacement: Schritt 4, Bild 3 von 3
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
  5. HP Deskjet D1660 Encoder Strip Replacement: Schritt 5, Bild 1 von 3 HP Deskjet D1660 Encoder Strip Replacement: Schritt 5, Bild 2 von 3 HP Deskjet D1660 Encoder Strip Replacement: Schritt 5, Bild 3 von 3
    • Looking at the printer from the front, carefully unhook the encoder strip from the left side.
    • Pull the strip to the left and push a little to unhook the strip.
    • Do the same thing on the other side by pulling to the right and pushing a little.
    • Pull the strip completely out from the cartridge holder.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 1-41, Maness Winter 2014 Mitglied von Cal Poly, Team 1-41, Maness Winter 2014
CPSU-MANESS-W14S1G41
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 4,282
