Einleitung
This guide will replace the gear guard, which will be hidden under the metal frame. It protects the gear from dirt and dust accumulation that would affect the printer's performance.
Was du brauchst
Lay the printer on its back.
Grab the paper tray by its right side and pull it to the left and up.
Open the frontal access panel by lifting it from the top.
Similar to the paper tray, grab it from the right side and pull it to the left and up.
Take out the two frontal 14.0 mm Torx #10 screws.
Carefully lift the frontal cover.
Remove the five 13.0 mm Torx #10 screws found on top of the frame.
Remove the four 9.0 mm Torx #10 smaller screws.
The gear guard will be located on the left side of the printer.
Grab the plastic guard and lift it up.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
