Einleitung
Does the printer button not work or stay on when you are trying to turn the printer off? Use this guide to replace the malfunctioning button. This will ensure that you have a working printer that will actually print.
Was du brauchst
Lay the printer on its back.
Grab the paper tray by its right side and pull it to the left and up.
Open the frontal access panel by lifting it from the top.
Similar to the paper tray, grab it from the right side and pull it to the left and up.
Take out the two frontal 14.0 mm Torx #10 screws.
Carefully lift the frontal cover.
Remove the two 13.0 mm Torx #10 screws.
Carefully lift it up. The button will be located under it.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
