Zum Hauptinhalt wechseln
HP Deskjet D1660 Power Button Replacement
Was du brauchst
  1. HP Deskjet D1660 Power Button Replacement, Top Cover: Schritt 1, Bild 1 von 1
    • Remove the back two 14.0 mm Torx #10 screws.
  2. HP Deskjet D1660 Power Button Replacement: Schritt 2, Bild 1 von 1
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
  3. HP Deskjet D1660 Power Button Replacement: Schritt 3, Bild 1 von 1
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
  4. HP Deskjet D1660 Power Button Replacement: Schritt 4, Bild 1 von 3 HP Deskjet D1660 Power Button Replacement: Schritt 4, Bild 2 von 3 HP Deskjet D1660 Power Button Replacement: Schritt 4, Bild 3 von 3
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
  5. HP Deskjet D1660 Power Button Replacement, Power Button: Schritt 5, Bild 1 von 1
    • Remove the strip that connects the printer to the front cover.
  6. HP Deskjet D1660 Power Button Replacement: Schritt 6, Bild 1 von 2 HP Deskjet D1660 Power Button Replacement: Schritt 6, Bild 2 von 2
    • Remove the two 13.0 mm Torx #10 screws.
    • Carefully lift it up. The button will be located under it.
  7. HP Deskjet D1660 Power Button Replacement: Schritt 7, Bild 1 von 1
    • Lift up the power button.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 1-41, Maness Winter 2014 Mitglied von Cal Poly, Team 1-41, Maness Winter 2014
CPSU-MANESS-W14S1G41
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 959
