Zum Hauptinhalt wechseln
HP Deskjet D1660 Rollers Replacement
Was du brauchst
  1. HP Deskjet D1660 Rollers Replacement, Top Cover: Schritt 1, Bild 1 von 1
    • Remove the back two 14.0 mm Torx #10 screws.
  2. HP Deskjet D1660 Rollers Replacement: Schritt 2, Bild 1 von 1
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
  3. HP Deskjet D1660 Rollers Replacement: Schritt 3, Bild 1 von 1
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
  4. HP Deskjet D1660 Rollers Replacement: Schritt 4, Bild 1 von 3 HP Deskjet D1660 Rollers Replacement: Schritt 4, Bild 2 von 3 HP Deskjet D1660 Rollers Replacement: Schritt 4, Bild 3 von 3
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
  5. HP Deskjet D1660 Rollers Replacement, Rollers: Schritt 5, Bild 1 von 2 HP Deskjet D1660 Rollers Replacement, Rollers: Schritt 5, Bild 2 von 2
    • Remove the five 13.0 mm Torx #10 screws found on top of the frame.
    • Remove the four 9.0 mm Torx #10 smaller screws.
  6. HP Deskjet D1660 Rollers Replacement: Schritt 6, Bild 1 von 2 HP Deskjet D1660 Rollers Replacement: Schritt 6, Bild 2 von 2
    • Lift the cover up using both of your hands.
    • Lift it carefully as a strip and motor will be connected to the bottom part of the printer.
  7. HP Deskjet D1660 Rollers Replacement: Schritt 7, Bild 1 von 2 HP Deskjet D1660 Rollers Replacement: Schritt 7, Bild 2 von 2
    • Locate the rollers, which will be on the bottom of the metal frame that holds the carriage.
    • Grab the rollers and remove them by pulling them to one side and lifting them up.
    • Do the same for the other three.
Abschluss
Cal Poly, Team 1-41, Maness Winter 2014 Mitglied von Cal Poly, Team 1-41, Maness Winter 2014
CPSU-MANESS-W14S1G41
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 15
Insgesamt: 1,217
