Zum Hauptinhalt wechseln
HP Deskjet F4480 Ink Cartridges Replacement
  1. HP Deskjet F4480 Ink Cartridges Replacement, Open front access panel: Schritt 1, Bild 1 von 1
    • Open the front access panel by placing your finger in the front slot and pulling gently.
  2. HP Deskjet F4480 Ink Cartridges Replacement, Ink Cartridges: Schritt 2, Bild 1 von 1
    • Slide the ink carriage until the the cartridges line up with the marked slots in the middle.
    • If the printer is on, then the carriage should have automatically slid to the middle when the front was opened. If not, ensure printer is unplugged and slide manually.
  3. HP Deskjet F4480 Ink Cartridges Replacement: Schritt 3, Bild 1 von 2 HP Deskjet F4480 Ink Cartridges Replacement: Schritt 3, Bild 2 von 2
    • Gently, but firmly depress the front of the ink cartridge you are removing until it is loose.
    • There may be a faint click when the cartridge comes loose.
  4. HP Deskjet F4480 Ink Cartridges Replacement: Schritt 4, Bild 1 von 1
    • Gently slide out cartridge.
    • Don't make contact with the ink head. The ink likes to get everywhere.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Tom Higdon
409 Reputation
1 Anleitung geschrieben
Cal Poly, Team 18-35, Regan Winter 2013 Mitglied von Cal Poly, Team 18-35, Regan Winter 2013
CPSU-REGAN-W13S18G35
5 Mitglieder
15 Anleitungen geschrieben
4 Kommentare
pls help me to operate to restore my hp deskjet f4480, I removed last wk the catridges to refill but when i starting to put back the catriges, i cant move the catriges holder, give me some tips pls, hoping a lot, ty
rico timbol - Antwort
please the drivers may be installed for using the scanner
sarvani valluru -
My daughter took out the ink cartridges on my F4480 hp desk jet and I don’t know how they go in correctly please help
Kelly Cook - Antwort
Why don’t you answer my question I just don’t want to force them or rake it
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 19
Insgesamt: 15,623
