Zum Hauptinhalt wechseln
HP ENVY ×360 15-bp106ng RAM Replacement
Was du brauchst
  1. HP ENVY ×360 15-bp106ng RAM Replacement, Shut down and turn over: Schritt 1, Bild 1 von 1
    • Shut down the laptop.
    • Turn it over and position it so that the display hinges face away from you.
  2. HP ENVY ×360 15-bp106ng RAM Replacement, Remove the exposed torx screws: Schritt 2, Bild 1 von 1
    • Remove the three exposed Torx T5 screws.
  3. HP ENVY ×360 15-bp106ng RAM Replacement, Remove back rubber strip: Schritt 3, Bild 1 von 1
    • Remove the rubber strip that is close to the display hinges.
    • Remove the adhesive strip along with the rubber to reveal the underlying screws.
  4. HP ENVY ×360 15-bp106ng RAM Replacement, Remove Phillips screws: Schritt 4, Bild 1 von 1
    • Remove the four Phillips P1 screws that are revealed by removing the rubber strip.
    • Note that the second screw hole from the right is not as deep as the other three.
  5. HP ENVY ×360 15-bp106ng RAM Replacement, Separate the housing: Schritt 5, Bild 1 von 3 HP ENVY ×360 15-bp106ng RAM Replacement, Separate the housing: Schritt 5, Bild 2 von 3 HP ENVY ×360 15-bp106ng RAM Replacement, Separate the housing: Schritt 5, Bild 3 von 3
    • Using an opening tool and opening picks, separate the bottom housing plate from the rest of the chassis on the left, bottom and right edges.
    • Lift and remove the plate.
  6. HP ENVY ×360 15-bp106ng RAM Replacement, Remove battery screws: Schritt 6, Bild 1 von 1
    • Remove the seven Phillips P1 screws that hold the battery in place.
    • Note that these battery screws have a different length than the P1 chassis screws.
  7. HP ENVY ×360 15-bp106ng RAM Replacement, Remove battery: Schritt 7, Bild 1 von 3 HP ENVY ×360 15-bp106ng RAM Replacement, Remove battery: Schritt 7, Bild 2 von 3 HP ENVY ×360 15-bp106ng RAM Replacement, Remove battery: Schritt 7, Bild 3 von 3
    • Using your hands, lift the battery up and towards yourself.
  8. HP ENVY ×360 15-bp106ng RAM Replacement, Remove tape from RAM housing: Schritt 8, Bild 1 von 1
    • Remove the black tape that is stuck to the large silver-black RAM housing.
  9. HP ENVY ×360 15-bp106ng RAM Replacement, Remove RAM housing: Schritt 9, Bild 1 von 3 HP ENVY ×360 15-bp106ng RAM Replacement, Remove RAM housing: Schritt 9, Bild 2 von 3 HP ENVY ×360 15-bp106ng RAM Replacement, Remove RAM housing: Schritt 9, Bild 3 von 3
    • Using a spudger, gently separate the RAM housing from the main board.
  10. HP ENVY ×360 15-bp106ng RAM Replacement, Remove RAM: Schritt 10, Bild 1 von 2 HP ENVY ×360 15-bp106ng RAM Replacement, Remove RAM: Schritt 10, Bild 2 von 2
    • Using both hands, bend outwards the two clips that hold the RAM module.
    • Remove the RAM module to the right and up.
    • Now insert the new RAM module, pushing it in from the right.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Adrian
276 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 26
Insgesamt: 2,220
