Zum Hauptinhalt wechseln
HP ENVY 5530 Front Panel Replacement
Was du brauchst
  1. HP ENVY 5530 Front Panel Replacement, Front Panel: Schritt 1, Bild 1 von 1
    • Lift up printer screen.
  2. HP ENVY 5530 Front Panel Replacement: Schritt 2, Bild 1 von 3 HP ENVY 5530 Front Panel Replacement: Schritt 2, Bild 2 von 3 HP ENVY 5530 Front Panel Replacement: Schritt 2, Bild 3 von 3
    • Use the Metal Spudger from the IFIXIT Toolkit to pry the left corner of the front panel.
    • Slowly pry the front panel by sliding the Metal Spudger along the border of the front panel.
  3. HP ENVY 5530 Front Panel Replacement: Schritt 3, Bild 1 von 2 HP ENVY 5530 Front Panel Replacement: Schritt 3, Bild 2 von 2
    • Remove the front panel by lifting each corner up.
    • Replace the front panel.
Abschluss
USF Tampa, Team 4-6, Meier Fall 2015 Mitglied von USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
4 Mitglieder
18 Anleitungen geschrieben
3 Kommentare
My HP Envy 5530 had a screw hidden beneath the label on the right side of the front panel. I used a knife to lift the label to access the screw.
rndymike - Antwort
Is the front panel from a 5532 compatible with the Envy 5530?
Armando Pagan - Antwort
Wish I would have seen the comment about the screw… fix your post… at least protect others from making the same mistake
Azpatch - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 21
Insgesamt: 1,849
