Einleitung
Paper trays help align papers once printed. Over time, the paper tray may lock itself or break. Ensure you have unplugged your device before you begin this repair.
Was du brauchst
Grab both sides of the printer and flip it away from you so the bottom is facing up.
Unscrew and remove the 13mm TR10 Torx Security screw, starting with the farthest screw on the left
Locate and remove middle 13mm TR10 Torx Security screw using a Torx screwdriver.
2 weitere Personen haben diese Anleitung absolviert.
