Zum Hauptinhalt wechseln
HP ENVY 5530 Power Supply Replacement
Was du brauchst
  1. HP ENVY 5530 Power Supply Replacement, AC Adaptor: Schritt 1, Bild 1 von 3 HP ENVY 5530 Power Supply Replacement, AC Adaptor: Schritt 1, Bild 2 von 3 HP ENVY 5530 Power Supply Replacement, AC Adaptor: Schritt 1, Bild 3 von 3
    • Open the the printer by lifting the top section. Make sure you're lifting from the lowest portion of the scanner section.
  2. HP ENVY 5530 Power Supply Replacement: Schritt 2, Bild 1 von 3 HP ENVY 5530 Power Supply Replacement: Schritt 2, Bild 2 von 3 HP ENVY 5530 Power Supply Replacement: Schritt 2, Bild 3 von 3
    • Locate 13mm TR10 Torx Security screw behind screen and remove using Torx screwdriver.
  3. HP ENVY 5530 Power Supply Replacement: Schritt 3, Bild 1 von 3 HP ENVY 5530 Power Supply Replacement: Schritt 3, Bild 2 von 3 HP ENVY 5530 Power Supply Replacement: Schritt 3, Bild 3 von 3
    • Remove case covering by lifting it up to reveal the power cord.
  4. HP ENVY 5530 Power Supply Replacement: Schritt 4, Bild 1 von 2 HP ENVY 5530 Power Supply Replacement: Schritt 4, Bild 2 von 2
    • Locate power cord.
    • Pull it out.
  5. HP ENVY 5530 Power Supply Replacement: Schritt 5, Bild 1 von 2 HP ENVY 5530 Power Supply Replacement: Schritt 5, Bild 2 von 2
    • Locate 13mm TR10 Torx Security screw behind screen and remove with screwdriver.
  6. HP ENVY 5530 Power Supply Replacement: Schritt 6, Bild 1 von 2 HP ENVY 5530 Power Supply Replacement: Schritt 6, Bild 2 von 2
    • Use a metal spudger around the edge to remove AC adapter cover.
  7. HP ENVY 5530 Power Supply Replacement: Schritt 7, Bild 1 von 1
    • Pull the AC adaptor up and out of its casing
  8. HP ENVY 5530 Power Supply Replacement: Schritt 8, Bild 1 von 3 HP ENVY 5530 Power Supply Replacement: Schritt 8, Bild 2 von 3 HP ENVY 5530 Power Supply Replacement: Schritt 8, Bild 3 von 3
    • Disconnect the wires from the AC adaptor.
    • Replace AC Adapter box. Reverse order of instructions for reassembly.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Justin
295 Reputation
1 Anleitung geschrieben
USF-Leahy-S18S1G1 Mitglied von USF-Leahy-S18S1G1
Community
3 Mitglieder
21 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 1,551
