Zum Hauptinhalt wechseln
HP Elite X2 1013 G3 Camera Replacement
Was du brauchst
  1. HP Elite X2 1013 G3 Camera Replacement, Screen: Schritt 1, Bild 1 von 1
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Camera Replacement: Schritt 2, Bild 1 von 2 HP Elite X2 1013 G3 Camera Replacement: Schritt 2, Bild 2 von 2
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Camera Replacement: Schritt 3, Bild 1 von 2 HP Elite X2 1013 G3 Camera Replacement: Schritt 3, Bild 2 von 2
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Camera Replacement: Schritt 4, Bild 1 von 2 HP Elite X2 1013 G3 Camera Replacement: Schritt 4, Bild 2 von 2
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Camera Replacement, Camera: Schritt 5, Bild 1 von 2 HP Elite X2 1013 G3 Camera Replacement, Camera: Schritt 5, Bild 2 von 2
    • Place the tip of an opening tool beneath the camera housing.
    • Slowly move the tool up and down until the camera pops off the laptop.
    • Remove the connector and lift the camera away from the laptop.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 221
