Zum Hauptinhalt wechseln
HP Elite X2 1013 G3 Fan Replacement
Was du brauchst
  1. HP Elite X2 1013 G3 Fan Replacement, Screen: Schritt 1, Bild 1 von 1
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Fan Replacement: Schritt 2, Bild 1 von 2 HP Elite X2 1013 G3 Fan Replacement: Schritt 2, Bild 2 von 2
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Fan Replacement: Schritt 3, Bild 1 von 2 HP Elite X2 1013 G3 Fan Replacement: Schritt 3, Bild 2 von 2
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Fan Replacement: Schritt 4, Bild 1 von 2 HP Elite X2 1013 G3 Fan Replacement: Schritt 4, Bild 2 von 2
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Fan Replacement, Battery: Schritt 5, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Fan Replacement: Schritt 6, Bild 1 von 1
    • Lift the battery out of the housing.
  7. HP Elite X2 1013 G3 Fan Replacement, Fan: Schritt 7, Bild 1 von 1
    • Undo the two small connectors by pulling gently.
  8. HP Elite X2 1013 G3 Fan Replacement: Schritt 8, Bild 1 von 1
    • Gently peel up three copper pieces of tape as shown.
    • Do not pull off completely.
  9. HP Elite X2 1013 G3 Fan Replacement: Schritt 9, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers or your fingers to carefully undo the indicated five connectors.
    • There will be a number of loose components after disconnecting the five connectors. If any are completely detached, set them aside.
  10. HP Elite X2 1013 G3 Fan Replacement: Schritt 10, Bild 1 von 2 HP Elite X2 1013 G3 Fan Replacement: Schritt 10, Bild 2 von 2
    • Using tweezers or your fingers, lift up and remove the plastic covering and set it aside.
  11. HP Elite X2 1013 G3 Fan Replacement: Schritt 11, Bild 1 von 1
    • Unscrew the two speaker/antenna module mounting 2mm screws using a Phillips #00 Screwdriver.
  12. HP Elite X2 1013 G3 Fan Replacement: Schritt 12, Bild 1 von 3 HP Elite X2 1013 G3 Fan Replacement: Schritt 12, Bild 2 von 3 HP Elite X2 1013 G3 Fan Replacement: Schritt 12, Bild 3 von 3
    • Use tweezers or your finger to unclasp and remove the upper right module with the copper tape and wire. Start by popping up the left side of the module.
    • Continue to pry up the module toward the right.
    • At this point, all connectors have been undone in previous steps, but if you notice any wires securing the module, do not keep pulling! Gently undo any connectors before proceeding.
    • Gently lift the whole module out, including the trailing wire.
  13. HP Elite X2 1013 G3 Fan Replacement: Schritt 13, Bild 1 von 3 HP Elite X2 1013 G3 Fan Replacement: Schritt 13, Bild 2 von 3 HP Elite X2 1013 G3 Fan Replacement: Schritt 13, Bild 3 von 3
    • Using a spudger, pry the left black plastic speaker/antenna module off of the frame as pictured. Start by lifting up the right side of the module, then slowly work your way down the module towards the right.
    • The slight cracking sound you will hear is the sounds of plastic clasps.
  14. HP Elite X2 1013 G3 Fan Replacement: Schritt 14, Bild 1 von 1
    • Undo the two indicated connectors near the fan using your fingers or tweezers.
  15. HP Elite X2 1013 G3 Fan Replacement: Schritt 15, Bild 1 von 1
    • Use the Phillips #00 Screwdriver to remove the eight 2 mm screws.
  16. HP Elite X2 1013 G3 Fan Replacement: Schritt 16, Bild 1 von 2 HP Elite X2 1013 G3 Fan Replacement: Schritt 16, Bild 2 von 2
    • Unscrew the single 2mm screw from the peripheral board with the same screwdriver, and remove the peripheral board from the motherboard.
  17. HP Elite X2 1013 G3 Fan Replacement: Schritt 17, Bild 1 von 2 HP Elite X2 1013 G3 Fan Replacement: Schritt 17, Bild 2 von 2
    • Remove the SD Card holder from the motherboard.
  18. HP Elite X2 1013 G3 Fan Replacement: Schritt 18, Bild 1 von 3 HP Elite X2 1013 G3 Fan Replacement: Schritt 18, Bild 2 von 3 HP Elite X2 1013 G3 Fan Replacement: Schritt 18, Bild 3 von 3
    • Using the Phillips 00 Screwdriver, remove the 2mm screw from the ribbon cable bracket.
    • Lift the ribbon cable bracket and connector off of the motherboard.
  19. HP Elite X2 1013 G3 Fan Replacement: Schritt 19, Bild 1 von 1
    • Undo the indicated ribbon connector.
  20. HP Elite X2 1013 G3 Fan Replacement: Schritt 20, Bild 1 von 2 HP Elite X2 1013 G3 Fan Replacement: Schritt 20, Bild 2 von 2
    • Lift up the flap on the right of the indicated plate, and lift the whole covering off.
  21. HP Elite X2 1013 G3 Fan Replacement: Schritt 21, Bild 1 von 1
    • Use tweezers or your fingers to undo the black ribbon connector.
  22. HP Elite X2 1013 G3 Fan Replacement: Schritt 22, Bild 1 von 1
    • Remove the whole assembly, granting access to the fans.
  23. HP Elite X2 1013 G3 Fan Replacement: Schritt 23, Bild 1 von 1
    • Use the Phillips #00 Screwdriver to remove the four 2mm screws.
    • If you are only removing one fan, remove the screws securing only that fan.
  24. HP Elite X2 1013 G3 Fan Replacement: Schritt 24, Bild 1 von 1
    • Lift the fan out.
Abschluss
Cal Poly, Team S9-G12, Maness Spring 2019 Mitglied von Cal Poly, Team S9-G12, Maness Spring 2019
CPSU-MANESS-S19S9G12
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 1,305
