Zum Hauptinhalt wechseln
HP Elite X2 1013 G3 Motherboard Replacement
Was du brauchst
  1. HP Elite X2 1013 G3 Motherboard Replacement, Screen: Schritt 1, Bild 1 von 1
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Motherboard Replacement: Schritt 2, Bild 1 von 2 HP Elite X2 1013 G3 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Motherboard Replacement: Schritt 3, Bild 1 von 2 HP Elite X2 1013 G3 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Motherboard Replacement: Schritt 4, Bild 1 von 2 HP Elite X2 1013 G3 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Motherboard Replacement, Battery: Schritt 5, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Lift the battery out of the housing.
  7. HP Elite X2 1013 G3 Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 1
    • Remove five screws from the heat sink using a Phillips #0 screwdriver.
    • Remove the heat sink from the tablet.
  8. HP Elite X2 1013 G3 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the single screw from the lightning cable connector using a Phillips #0 screwdriver.
    • Lift the lightning cable connector out of the tablet.
  9. HP Elite X2 1013 G3 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Remove the ten screws holding down the motherboard using a Phillips #0 screwdriver.
  10. HP Elite X2 1013 G3 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Remove the motherboard from the tablet.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 32
Insgesamt: 537
