Einleitung
When your device isn’t properly loading files, the storage may be the issue. This guide will teach you how to replace the SSD in your device.
Was du brauchst
Flip the device over so the base is facing the ceiling.
Lift up the tablet stand.
Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
Flip the tablet over with the screen facing upwards.
Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
Use the Phillips #00 screwdriver to remove the six 2 mm screws.
Gently disconnect the two connectors.
Using the Phillips #00 Screwdriver, remove the single indicated screw.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
