Zum Hauptinhalt wechseln
HP Elite X2 G4 Display Assembly Replacement
Was du brauchst
  1. HP Elite X2 G4 Display Assembly Replacement, Display Assembly: Schritt 1, Bild 1 von 1
    • Open the kickstand.
    • Remove the four 3 mm T5 Torx-head screws that secure the display assembly.
  2. HP Elite X2 G4 Display Assembly Replacement: Schritt 2, Bild 1 von 1
    • Use a suction sup to carefully detach the display assembly in the following order: top-right corner, top-left corner, bottom-right corner and bottom-left corner.
  3. HP Elite X2 G4 Display Assembly Replacement: Schritt 3, Bild 1 von 1
    • Slowly lift the display panel until you have access to the battery connector on the motherboard (approx. 90 degrees).
  4. HP Elite X2 G4 Display Assembly Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the battery cable from its motherboard connector.
    • Remove the tape that covers the touchscreen and display panel ZIF connectors.
  5. HP Elite X2 G4 Display Assembly Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the touchscreen ribbon cable from the motherboard.
    • Remove the display panel assembly.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Goncalo Felix
325 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 4-4, Sinclaire Fall 2022 Mitglied von UMass Dartmouth, Team 4-4, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G4
5 Mitglieder
Ein Kommentar
Boa tarde Gonçalo.
Sabe dizer-me onde posso comprar um ecrã original para o meu HP Elite X2 G4?
Obrigado
Pedro Santos
Pedro_Neno - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 40
Insgesamt: 556
