Einleitung
This guide will go through on how to replace your device's display panel (screen). To start with the replacement process, we recommend watching this video.
Was du brauchst
Open the kickstand.
Remove the four 3 mm T5 Torx-head screws that secure the display assembly.
Use a suction sup to carefully detach the display assembly in the following order: top-right corner, top-left corner, bottom-right corner and bottom-left corner.
Slowly lift the display panel until you have access to the battery connector on the motherboard (approx. 90 degrees).
Disconnect the battery cable from its motherboard connector.
Remove the tape that covers the touchscreen and display panel ZIF connectors.
Disconnect the touchscreen ribbon cable from the motherboard.
Remove the display panel assembly.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Boa tarde Gonçalo.
Sabe dizer-me onde posso comprar um ecrã original para o meu HP Elite X2 G4?
Obrigado
Pedro Santos
