Einleitung
Batteries are often the first components to wear out in electronic devices and as a result are a common problem. A dead battery can be frustrating, but fortunately replacing the battery on the HP Elite x2 1012 G2 is quick and easy.
Was du brauchst
Turn the device over so the screen is facing you.
Place a suction cup firmly onto a corner of the screen.
Lift up gently until you see the screen separate from the casing.
Repeat this process for all four corners.
Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
Remove all six Phillips 3 mm screws around the battery by rotating in the counterclockwise direction with a Phillips screwdriver.
Remove the battery's connector by pushing both sides of the tab towards yourself with a plastic opening tool.
13 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
Bien tout en image
Hi, after the replacement battery
toch not working, help pls?
