Was du brauchst
Turn the device over so the screen is facing you.
Place a suction cup firmly onto a corner of the screen.
Lift up gently until you see the screen separate from the casing.
Repeat this process for all four corners.
Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
Remove all six Phillips 3 mm screws around the battery by rotating in the counterclockwise direction with a Phillips screwdriver.
Remove the battery's connector by pushing both sides of the tab towards yourself with a plastic opening tool.
Use the spudger tools to lift the copper tape and expose the screws.
Use a Phillips #00 screwdriver to remove the final two 3 mm screws that secure the fan.
Use a spudger to lift the connection for the fan and disconnect the plug from the motherboard.
2 weitere Personen haben diese Anleitung absolviert.
