Zum Hauptinhalt wechseln
HP Elite x2 1012 G2 Speakers Replacement
Was du brauchst
  1. HP Elite x2 1012 G2 Speakers Replacement, Screen: Schritt 1, Bild 1 von 1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Speakers Replacement: Schritt 2, Bild 1 von 3 HP Elite x2 1012 G2 Speakers Replacement: Schritt 2, Bild 2 von 3 HP Elite x2 1012 G2 Speakers Replacement: Schritt 2, Bild 3 von 3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Speakers Replacement: Schritt 3, Bild 1 von 2 HP Elite x2 1012 G2 Speakers Replacement: Schritt 3, Bild 2 von 2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Speakers Replacement: Schritt 4, Bild 1 von 1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Speakers Replacement: Schritt 5, Bild 1 von 3 HP Elite x2 1012 G2 Speakers Replacement: Schritt 5, Bild 2 von 3 HP Elite x2 1012 G2 Speakers Replacement: Schritt 5, Bild 3 von 3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Speakers Replacement: Schritt 6, Bild 1 von 2 HP Elite x2 1012 G2 Speakers Replacement: Schritt 6, Bild 2 von 2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Speakers Replacement, Speakers: Schritt 7, Bild 1 von 1
    • Identify the speaker locations.
  8. HP Elite x2 1012 G2 Speakers Replacement: Schritt 8, Bild 1 von 2 HP Elite x2 1012 G2 Speakers Replacement: Schritt 8, Bild 2 von 2
    • Remove the antennae connections from both the WiFi card and the wireless cellular M.2 card.
    • Gently pull the black and red wire free at the motherboard connector.
  9. HP Elite x2 1012 G2 Speakers Replacement: Schritt 9, Bild 1 von 3 HP Elite x2 1012 G2 Speakers Replacement: Schritt 9, Bild 2 von 3 HP Elite x2 1012 G2 Speakers Replacement: Schritt 9, Bild 3 von 3
    • Use the spudger tool to remove the speakers from the housing.
  10. HP Elite x2 1012 G2 Speakers Replacement: Schritt 10, Bild 1 von 2 HP Elite x2 1012 G2 Speakers Replacement: Schritt 10, Bild 2 von 2
    • On the right speaker, the black antena piece must be removed before the speaker can be accessed.
  11. HP Elite x2 1012 G2 Speakers Replacement: Schritt 11, Bild 1 von 2 HP Elite x2 1012 G2 Speakers Replacement: Schritt 11, Bild 2 von 2
    • Now remove the green and white wires from the cable management track and the speakers will be completely removed from the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
WesleyEagleson
431 Reputation
3 Anleitungen geschrieben
IUPUI, Team S13-G13, Wilson Spring 2019 Mitglied von IUPUI, Team S13-G13, Wilson Spring 2019
IUPUI-WILSON-S19S13G13
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 27
Insgesamt: 1,219
