Zum Hauptinhalt wechseln
HP Elite x2 G1 1012 Display Replacement
Was du brauchst
  1. HP Elite x2 G1 1012 Display Replacement, Display: Schritt 1, Bild 1 von 1
    • Be sure to power off and unplug your device before you begin your repair.
    • With the screen face down, lift up the stand as far as it goes.
    • Make sure not to force it past the resting point.
  2. HP Elite x2 G1 1012 Display Replacement: Schritt 2, Bild 1 von 2 HP Elite x2 G1 1012 Display Replacement: Schritt 2, Bild 2 von 2
    • Use a T5 driver to remove the six screws on the back of the tablet.
  3. HP Elite x2 G1 1012 Display Replacement: Schritt 3, Bild 1 von 1
    • After removing the screws, delicately close the stand.
    • Flip the tablet on its back so that the screen is facing up.
  4. HP Elite x2 G1 1012 Display Replacement: Schritt 4, Bild 1 von 2 HP Elite x2 G1 1012 Display Replacement: Schritt 4, Bild 2 von 2
    • Use the suction cup to carefully separate the screen from the device. Pull upwards with a fluid and smooth motion.
    • Do not lift too fast! There will still be wires connecting the screen to the device. Make sure they are not tampered with.
  5. HP Elite x2 G1 1012 Display Replacement: Schritt 5, Bild 1 von 3 HP Elite x2 G1 1012 Display Replacement: Schritt 5, Bild 2 von 3 HP Elite x2 G1 1012 Display Replacement: Schritt 5, Bild 3 von 3
    • Remove the tape on the lower left side of the screen.
    • Underneath the tape, disconnect the LCM cable, the larger wire that was underneath the tape, from the back of the tablet screen.
  6. HP Elite x2 G1 1012 Display Replacement: Schritt 6, Bild 1 von 2 HP Elite x2 G1 1012 Display Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the flex cable from the device using the spudger.
    • Remove the Display Assembly from the device.
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
4 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team S24-G7, Maness Spring 2018 Mitglied von Cal Poly, Team S24-G7, Maness Spring 2018
CPSU-MANESS-S18S24G7
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 31
Insgesamt: 3,811
