Zum Hauptinhalt wechseln
HP Elite x2 G1 1012 SSD Card Replacement
Was du brauchst
  1. HP Elite x2 G1 1012 SSD Card Replacement, Display: Schritt 1, Bild 1 von 1
    • Be sure to power off and unplug your device before you begin your repair.
    • With the screen face down, lift up the stand as far as it goes.
    • Make sure not to force it past the resting point.
  2. HP Elite x2 G1 1012 SSD Card Replacement: Schritt 2, Bild 1 von 2 HP Elite x2 G1 1012 SSD Card Replacement: Schritt 2, Bild 2 von 2
    • Use a T5 driver to remove the six screws on the back of the tablet.
  3. HP Elite x2 G1 1012 SSD Card Replacement: Schritt 3, Bild 1 von 1
    • After removing the screws, delicately close the stand.
    • Flip the tablet on its back so that the screen is facing up.
  4. HP Elite x2 G1 1012 SSD Card Replacement: Schritt 4, Bild 1 von 2 HP Elite x2 G1 1012 SSD Card Replacement: Schritt 4, Bild 2 von 2
    • Use the suction cup to carefully separate the screen from the device. Pull upwards with a fluid and smooth motion.
    • Do not lift too fast! There will still be wires connecting the screen to the device. Make sure they are not tampered with.
  5. HP Elite x2 G1 1012 SSD Card Replacement: Schritt 5, Bild 1 von 3 HP Elite x2 G1 1012 SSD Card Replacement: Schritt 5, Bild 2 von 3 HP Elite x2 G1 1012 SSD Card Replacement: Schritt 5, Bild 3 von 3
    • Remove the tape on the lower left side of the screen.
    • Underneath the tape, disconnect the LCM cable, the larger wire that was underneath the tape, from the back of the tablet screen.
  6. HP Elite x2 G1 1012 SSD Card Replacement: Schritt 6, Bild 1 von 2 HP Elite x2 G1 1012 SSD Card Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the flex cable from the device using the spudger.
    • Remove the Display Assembly from the device.
  7. HP Elite x2 G1 1012 SSD Card Replacement, SSD Card: Schritt 7, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove the screw on the left hand side of the card.
  8. HP Elite x2 G1 1012 SSD Card Replacement: Schritt 8, Bild 1 von 1
    • Slightly lift the card up and then remove the SSD card from the device.
    • As you slide it out, make sure it gets unplugged from the port. Do not continue to tug on a stuck port.
Abschluss
Colin Mika
943 Reputation
6 Anleitungen geschrieben
Cal Poly, Team S24-G7, Maness Spring 2018 Mitglied von Cal Poly, Team S24-G7, Maness Spring 2018
CPSU-MANESS-S18S24G7
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 41
Insgesamt: 4,152
