Einleitung
If the speaker produce buzzing, crackling sound or not operational, there might be a problem with your speaker. This guide will help you go through the process of replacing the faulty speakers.
Before going through the replacement process, make sure your tablet is turned off and not connected to the power cord.
Was du brauchst
While the screen is facing down, remove six 3.0 mm Torx T5 screws under the stand.
Detach flex cable from motherboard using tweezers.
2 weitere Personen haben diese Anleitung absolviert.
