Einleitung
If you are having wireless connectivity issues, the WWAN Card may need to be replaced. Use this guide to properly remove it.
Was du brauchst
After removing the screws, delicately close the stand.
Flip the tablet on its back so that the screen is facing up.
Use the suction cup to carefully separate the screen from the device. Pull upwards with a fluid and smooth motion.
Remove the tape on the lower left side of the screen.
Underneath the tape, disconnect the LCM cable, the larger wire that was underneath the tape, from the back of the tablet screen.
Disconnect the flex cable from the device using the spudger.
Remove the Display Assembly from the device.
Use a Phillips #0 screwdriver to remove the screw from the left hand side of the board.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Remove the two black wires that are connected to the board with a pair of tweezers.
Use the spudger to lift the board up slightly.
Continue to lift and slide the WWAN card until it is completely removed from the device.
