Zum Hauptinhalt wechseln
HP Elite x2 G4 Motherboard Replacement
Was du brauchst
  1. HP Elite x2 G4 Motherboard Replacement, Display Assembly: Schritt 1, Bild 1 von 1
    • Open the kickstand.
    • Remove the four 3 mm T5 Torx-head screws that secure the display assembly.
  2. HP Elite x2 G4 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Use a suction sup to carefully detach the display assembly in the following order: top-right corner, top-left corner, bottom-right corner and bottom-left corner.
  3. HP Elite x2 G4 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Slowly lift the display panel until you have access to the battery connector on the motherboard (approx. 90 degrees).
  4. HP Elite x2 G4 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the battery cable from its motherboard connector.
    • Remove the tape that covers the touchscreen and display panel ZIF connectors.
  5. HP Elite x2 G4 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the touchscreen ribbon cable from the motherboard.
    • Remove the display panel assembly.
  6. HP Elite x2 G4 Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Remove the two 2.5 mm Phillips #0 screws that secure the USB bracket to the motherboard.
  7. HP Elite x2 G4 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Lift the USB bracket off of the motherboard and remove it.
    • Remove the four 2 mm Phillips #0 screws that secure the motherboard.
  8. HP Elite x2 G4 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • You would then disconnect the following cables from the motherboard:
    • - Left and right speaker cables.
    • - Volume button board ribbon cable.
    • - Left and right hall sensor ribbon cables.
    • - Fingerprint reader ribbon cable.
    • - WLAN antenas.
    • - SIM cardboard ribbon cable.
    • - POGO ribbon cable.
  9. HP Elite x2 G4 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Slide the external connectors out of the cutout in the display enclosure and remove.
    • Do not remove the BIOS board from the motherboard. The motherboard must be returned with the BIOS board attached.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Goncalo Felix
325 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 4-4, Sinclaire Fall 2022 Mitglied von UMass Dartmouth, Team 4-4, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G4
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 36
Insgesamt: 491
