Einleitung
Use this guide to replace the lower case on a HP EliteBook 725 G3.
Was du brauchst
Remove the ten 2.5 mm-long Phillips #0 screws securing the lower case.
Use the pointed tip of a spudger to remove the rubber stoppers on the lower case.
Remove the remaining 2.5 mm-long Phillips screws that secure the lower case.
Thelower has a click-release mechanism that is shown in the photos where the SD card is inserted.
Push in on this mechanism and remove the lower case.
Abschluss
