Zum Hauptinhalt wechseln
HP EliteBook 725 G3 Motherboard Replacement
Was du brauchst
  1. HP EliteBook 725 G3 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the two 2.5 mm Phillips #00 screws securing the battery.
  2. HP EliteBook 725 G3 Motherboard Replacement: Schritt 2, Bild 1 von 3 HP EliteBook 725 G3 Motherboard Replacement: Schritt 2, Bild 2 von 3 HP EliteBook 725 G3 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Lift and remove the battery.
  3. HP EliteBook 725 G3 Motherboard Replacement, Fan and Heat Sink Assembly: Schritt 3, Bild 1 von 2 HP EliteBook 725 G3 Motherboard Replacement, Fan and Heat Sink Assembly: Schritt 3, Bild 2 von 2
    • Remove the six 2.5 mm-long Phillips #00 screws securing the fan and heat sink assembly.
  4. HP EliteBook 725 G3 Motherboard Replacement: Schritt 4, Bild 1 von 3 HP EliteBook 725 G3 Motherboard Replacement: Schritt 4, Bild 2 von 3 HP EliteBook 725 G3 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Push the fan and heat sink assembly directly out of its socket with the tip of a spudger or your fingernails.
  5. HP EliteBook 725 G3 Motherboard Replacement: Schritt 5, Bild 1 von 2 HP EliteBook 725 G3 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Lift the fan and heat sink assembly up and away from the motherboard to remove it.
  6. HP EliteBook 725 G3 Motherboard Replacement, Wi-Fi Card: Schritt 6, Bild 1 von 2 HP EliteBook 725 G3 Motherboard Replacement, Wi-Fi Card: Schritt 6, Bild 2 von 2
    • Remove the single Phillips #00 screw securing the Wi-Fi card.
    • Use the pointed end of a spudger to pry up and disconnect the two coaxial connectors.
  7. HP EliteBook 725 G3 Motherboard Replacement: Schritt 7, Bild 1 von 3 HP EliteBook 725 G3 Motherboard Replacement: Schritt 7, Bild 2 von 3 HP EliteBook 725 G3 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Pull the Wi-Fi card directly out of its socket.
  8. HP EliteBook 725 G3 Motherboard Replacement, SSD: Schritt 8, Bild 1 von 1
    • Remove the single Phillips #00 screw securing the SSD.
  9. HP EliteBook 725 G3 Motherboard Replacement: Schritt 9, Bild 1 von 3 HP EliteBook 725 G3 Motherboard Replacement: Schritt 9, Bild 2 von 3 HP EliteBook 725 G3 Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Pull the SSD directly out of its socket.
  10. HP EliteBook 725 G3 Motherboard Replacement, RAM Stick: Schritt 10, Bild 1 von 2 HP EliteBook 725 G3 Motherboard Replacement, RAM Stick: Schritt 10, Bild 2 von 2
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
  11. HP EliteBook 725 G3 Motherboard Replacement: Schritt 11, Bild 1 von 2 HP EliteBook 725 G3 Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Gently pull the RAM module directly out of its socket.
  12. HP EliteBook 725 G3 Motherboard Replacement, Motherboard: Schritt 12, Bild 1 von 3 HP EliteBook 725 G3 Motherboard Replacement, Motherboard: Schritt 12, Bild 2 von 3 HP EliteBook 725 G3 Motherboard Replacement, Motherboard: Schritt 12, Bild 3 von 3
    • Remove the ten 2.5 mm-long Phillips #00 screws securing the motherboard.
  13. HP EliteBook 725 G3 Motherboard Replacement: Schritt 13, Bild 1 von 2 HP EliteBook 725 G3 Motherboard Replacement: Schritt 13, Bild 2 von 2
    • Flip up the black locking flap securing the ribbon cable and disconnect the cable.
  14. HP EliteBook 725 G3 Motherboard Replacement: Schritt 14, Bild 1 von 3 HP EliteBook 725 G3 Motherboard Replacement: Schritt 14, Bild 2 von 3 HP EliteBook 725 G3 Motherboard Replacement: Schritt 14, Bild 3 von 3
    • Disconnect the small group of wires near the hinge of the laptop by gently squeezing the sides and pulling it out
  15. HP EliteBook 725 G3 Motherboard Replacement: Schritt 15, Bild 1 von 2 HP EliteBook 725 G3 Motherboard Replacement: Schritt 15, Bild 2 von 2
    • Gently grab the motherboard and slowly maneuver it out.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
UMass Dartmouth, Team 1-4, Botvin Fall 2025 Mitglied von UMass Dartmouth, Team 1-4, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 92
