Zum Hauptinhalt wechseln
HP EliteBook 745 G6 RAM Replacement
Was du brauchst
  1. HP EliteBook 745 G6 RAM Replacement, RAM: Schritt 1, Bild 1 von 1
    • Type CMD in the Start Menu and open Command Prompt.
    • Type the following command to view memory details and press Enter.
    • wmic memorychip get devicelocator, manufacturer, partnumber, serialnumber, capacity, speed, memorytype, formfactor.
  2. HP EliteBook 745 G6 RAM Replacement: Schritt 2, Bild 1 von 1
    • Power off the Notebook.
    • Select the Start button.
    • Select the Power button.
    • Select Shut down.
    • Disconnect the power adapter.
  3. HP EliteBook 745 G6 RAM Replacement: Schritt 3, Bild 1 von 2 HP EliteBook 745 G6 RAM Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    • Turn the notebook upside down on a flat surface.
    • Loosen the six captive screws and the two inset captive screws counter-clockwise with the Phillips #00 screwdriver.
    • Pry the bottom cover with plastic card or spudger at the bottom right corner.
    • Lift the bottom cover off with plastic card.
  4. HP EliteBook 745 G6 RAM Replacement: Schritt 4, Bild 1 von 2 HP EliteBook 745 G6 RAM Replacement: Schritt 4, Bild 2 von 2
    Anti-Static Wrist Strap
    $7.95
  5. HP EliteBook 745 G6 RAM Replacement: Schritt 5, Bild 1 von 2 HP EliteBook 745 G6 RAM Replacement: Schritt 5, Bild 2 von 2
    • Be sure to ground yourself by wearing anti-static wrist strap.
    • Do not remove memory shielding from the system board when replacing memory.
    • The socket labeled 2 houses the expansion memory module and the socket labeled 1 houses the primary memory module.
    • Spread the retaining tabs on each side of the memory module slot to release the memory module.
    • Pull the memory module away from the slot at an angle.
  6. HP EliteBook 745 G6 RAM Replacement: Schritt 6, Bild 1 von 2 HP EliteBook 745 G6 RAM Replacement: Schritt 6, Bild 2 von 2
    • Insert the memory module into the slot at an angle.
    • Push down the center of memory module until the retaining tabs lock the RAM stick.
  7. HP EliteBook 745 G6 RAM Replacement: Schritt 7, Bild 1 von 1
    • Insert the battery cable into the system board.
  8. HP EliteBook 745 G6 RAM Replacement: Schritt 8, Bild 1 von 2 HP EliteBook 745 G6 RAM Replacement: Schritt 8, Bild 2 von 2
    • Push down the bottom cover at the four corner and center.
    • Tighten the six captive screws and the two inset captive screws clockwise with Phillips #00 screwdriver.
  9. HP EliteBook 745 G6 RAM Replacement: Schritt 9, Bild 1 von 1
    • Push the power button.
  10. HP EliteBook 745 G6 RAM Replacement: Schritt 10, Bild 1 von 2 HP EliteBook 745 G6 RAM Replacement: Schritt 10, Bild 2 von 2
    • Right-click on the taskbar.
    • Select the “Task Manager”.
    • Select the "Performance".
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Mengqi Shi
208 Reputation
1 Anleitung geschrieben
York University, Team S1-G27, O'Regan Summer 2021 Mitglied von York University, Team S1-G27, O'Regan Summer 2021
YORK-O'REGAN-SU21S1G27
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 19
Letzte 30 Tage: 74
Insgesamt: 2,759
