Einleitung
This guide will show you how to replace the RAM in the HP EliteBook 820 G3 laptop. Before beginning this guide, ensure to unplug your device from the electric outlet and charging port. Power off the device completely by holding down the power key.
Was du brauchst
Remove the SD card blank and the single 3 mm screw beneath it using a Phillips #00 screwdriver.
Lift off the back cover with your hands.
Pull the two clips on either side of the RAM sideways at the same time.
Pull the RAM stick out.
Repeat this step with the other RAM stick.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
