Einleitung
Use this guide to replace the heat sink and fan of your HP EliteBook 840 Aero G8. The heat sink and fan need to be replaced if your device is overheating and not performing properly. Be sure to remove the battery before removing the heat sink and fan, as potential for electric shock is present.
Was du brauchst
Use a JIS #0 screwdriver to unscrew the three 6.73 mm case retention screws.
Use a JIS #0 screwdriver to unscrew and remove the two 8.76 mm screws.
Use the Halberd Spudger to remove the cable running along the bottom of the battery
Use a JIS #0 screwdriver to unscrew the four 7 mm screws that secure the battery.
Use the JIS #0 screwdriver to remove the three 5.33 mm screws that secure the fan.
