Zum Hauptinhalt wechseln
HP EliteBook 840 Aero G8 Wi-Fi Card Replacement
Was du brauchst
  1. HP EliteBook 840 Aero G8 Wi-Fi Card Replacement, Battery: Schritt 1, Bild 1 von 2 HP EliteBook 840 Aero G8 Wi-Fi Card Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use a JIS #0 screwdriver to unscrew the three 6.73 mm case retention screws.
    • Use a JIS #0 screwdriver to unscrew and remove the two 8.76 mm screws.
  2. HP EliteBook 840 Aero G8 Wi-Fi Card Replacement: Schritt 2, Bild 1 von 2 HP EliteBook 840 Aero G8 Wi-Fi Card Replacement: Schritt 2, Bild 2 von 2
    • Use the Halberd Spudger to remove the cable running along the bottom of the battery
  3. HP EliteBook 840 Aero G8 Wi-Fi Card Replacement: Schritt 3, Bild 1 von 2 HP EliteBook 840 Aero G8 Wi-Fi Card Replacement: Schritt 3, Bild 2 von 2
    • Disconnect the cable connected the battery to the motherboard
  4. HP EliteBook 840 Aero G8 Wi-Fi Card Replacement: Schritt 4, Bild 1 von 2 HP EliteBook 840 Aero G8 Wi-Fi Card Replacement: Schritt 4, Bild 2 von 2
    • Use a JIS #0 screwdriver to unscrew the four 7 mm screws that secure the battery.
  5. HP EliteBook 840 Aero G8 Wi-Fi Card Replacement: Schritt 5, Bild 1 von 1
    • Slide the battery out of the clips to remove it from the laptop.
  6. HP EliteBook 840 Aero G8 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 6, Bild 1 von 2 HP EliteBook 840 Aero G8 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 6, Bild 2 von 2
    • Use the hook end of the halberd spudger to remove the black and white antenna cables connected to the Wi-Fi card
  7. HP EliteBook 840 Aero G8 Wi-Fi Card Replacement: Schritt 7, Bild 1 von 2 HP EliteBook 840 Aero G8 Wi-Fi Card Replacement: Schritt 7, Bild 2 von 2
    • Use a JIS #0 screwdriver to unscrew the single 2 mm screw that secures the Wi-Fi card.
  8. HP EliteBook 840 Aero G8 Wi-Fi Card Replacement: Schritt 8, Bild 1 von 1
    • Disconnect the WiFi card and gently pull it horizontally to free it from the motherboard.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 28
Insgesamt: 687
