Zum Hauptinhalt wechseln
HP EliteBook 840 G3 Keyboard Replacement
  1. HP EliteBook 840 G3 Keyboard Replacement, Safely remove the keyboard: Schritt 1, Bild 1 von 1
    • HP's service manual for this computer is a great document. But on page 52, it says to "insert a thin tool into the hole beside the fan assembly". But their illustration doesn't actually show the location of that hole. Worse yet, molded into the plastic, there is a keyboard symbol and an arrow POINTING THE WRONG WAY (zoom into my picture, you'll see what I mean).
    Frag FixBot
    Kommentar hinzufügen
    • To save you trouble, I've outlined the hole in RED in the photo I have attached. You can remove the keyboard by using the back end of your spudger, a small wooden dowel or similar non-conductive tool, and applying slight pressure until the keyboard lifts up enough for you to get your pick, or fingernails under it.
    Frag FixBot
    • The rest is easy. Just be careful not to pull the keyboard away until you carefully disconnect the keyboard cable (and possibly an additional power cable if your keyboard is backlit).
    Frag FixBot
Ziellinie
8 weitere Personen haben diese Anleitung absolviert.
5 Kommentare zur Anleitung
this is not a elitebook 840 g3 inside. There is a bracket where you have to remove 2 screws to remove the keyboard
ncata - Antwort Teilen
For a person who commented above: you are wrong, this is how elitebook 840 g3 looks like. After removing 2 screws I got stuck at the same issue with the arrow as the author explains. THANK YOU FOR THIS GUIDE IT SAVED ME A LOT OF TIME !
Albert Einstein - Antwort Teilen
Update - HP's service manual for their computers has disappeared, but they have a lot more of their own service videos on their YouTube channel. In this particular case, they demonstrate in this video using a wooden dowel how to pop they keyboard loose like their manual describes. The audio is actually just the computer reading the steps from their manual. If any one can find the manual, please add it here.
Richard Brooks - Antwort Teilen
This repair manual is still the link above (http://h10032.www1.hp.com/ctg/Manual/c04...) just with .pdf added to it. (So, http://h10032.www1.hp.com/ctg/Manual/c04...) Although, it is a shame to see them not searchable on HP's website.
CJ Loophole - Antwort Teilen
Meu computador está com problema de não ligar, apenas piscando ledes
Alexis Medicozinho Áleck - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 27
Letzte 30 Tage: 193
Insgesamt: 6,898
