Zum Hauptinhalt wechseln
HP EliteBook 840 G7 Wireless Card Replacement
Was du brauchst
  1. HP EliteBook 840 G7 Wireless Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop on its back.
  2. HP EliteBook 840 G7 Wireless Card Replacement: Schritt 2, Bild 1 von 1
    • Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
  3. HP EliteBook 840 G7 Wireless Card Replacement: Schritt 3, Bild 1 von 1
    • Remove the back cover to expose the hardware.
  4. HP EliteBook 840 G7 Wireless Card Replacement: Schritt 4, Bild 1 von 3 HP EliteBook 840 G7 Wireless Card Replacement: Schritt 4, Bild 2 von 3 HP EliteBook 840 G7 Wireless Card Replacement: Schritt 4, Bild 3 von 3
    • Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
    • Remove the connector that connects the battery to the motherboard.
  5. HP EliteBook 840 G7 Wireless Card Replacement: Schritt 5, Bild 1 von 3 HP EliteBook 840 G7 Wireless Card Replacement: Schritt 5, Bild 2 von 3 HP EliteBook 840 G7 Wireless Card Replacement: Schritt 5, Bild 3 von 3
    • Lift up the battery with you hands or tools.
  6. HP EliteBook 840 G7 Wireless Card Replacement, Wireless Card: Schritt 6, Bild 1 von 1
    • Detach both wires from the wireless card.
  7. HP EliteBook 840 G7 Wireless Card Replacement: Schritt 7, Bild 1 von 2 HP EliteBook 840 G7 Wireless Card Replacement: Schritt 7, Bild 2 von 2
    • Use a Phillips # 1 screwdriver, remove the one 2.5 mm screw securing the wireless card.
  8. HP EliteBook 840 G7 Wireless Card Replacement: Schritt 8, Bild 1 von 1
    • Remove the wireless card
Abschluss
Ein Kommentar
What model wireless card are you using?
David Bauer - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 39
Insgesamt: 827
