Zum Hauptinhalt wechseln
HP EliteBook 8440p LCD Replacement
Was du brauchst
  1. HP EliteBook 8440p LCD Replacement, Remove rubber pads: Schritt 1, Bild 1 von 2 HP EliteBook 8440p LCD Replacement, Remove rubber pads: Schritt 1, Bild 2 von 2
    • Remove the ROUND rubber pads along the edge of the monitor. One in each corner. The center bottom ones do not cover screws.
    • They are held on with a lite adhesive
  2. HP EliteBook 8440p LCD Replacement, Remove 4 T8 Screws: Schritt 2, Bild 1 von 1
    • Under the rubber pads are T8 screws.
    • Remove the 4 of them. (One each corner)
  3. HP EliteBook 8440p LCD Replacement, Separate the face from the display: Schritt 3, Bild 1 von 3 HP EliteBook 8440p LCD Replacement, Separate the face from the display: Schritt 3, Bild 2 von 3 HP EliteBook 8440p LCD Replacement, Separate the face from the display: Schritt 3, Bild 3 von 3
    • At this point, the face is held on with little clips and adhesive. Go around the edge of the laptop screen gently prying the clips open.
    • The adhesive is on the inner edge. Since I didn’t care about the current screen, I also gripped the inner edge of the face, and pushed against the screen a little.
  4. HP EliteBook 8440p LCD Replacement, Separate the back cover from LCD: Schritt 4, Bild 1 von 3 HP EliteBook 8440p LCD Replacement, Separate the back cover from LCD: Schritt 4, Bild 2 von 3 HP EliteBook 8440p LCD Replacement, Separate the back cover from LCD: Schritt 4, Bild 3 von 3
    • Each lower corner of the screen has two PH0 screws. Remove them.
    • Note that the two holes with screws have little triangle marks. This will make your reassembly easier when you try to remember which two holes to use.
    • Lift the screen 45º of the laptop. The back should now be disconnected from the main frame of the display, and should be able to be pulled up to 90º.
  5. HP EliteBook 8440p LCD Replacement, Remove Data cable from back of LCD screen: Schritt 5, Bild 1 von 3 HP EliteBook 8440p LCD Replacement, Remove Data cable from back of LCD screen: Schritt 5, Bild 2 von 3 HP EliteBook 8440p LCD Replacement, Remove Data cable from back of LCD screen: Schritt 5, Bild 3 von 3
    • On the back of the display, 4” (10cm) from the left side is a small data cable, unplug it.
    • There is a piece of clear tape over the connector, and a barcode with a clear backing. Carefully remove this.
  6. HP EliteBook 8440p LCD Replacement, Separate the LCD from the frame: Schritt 6, Bild 1 von 1
    • Remove the three PH0 screws from each side of the LCD assembly.
  7. HP EliteBook 8440p LCD Replacement, Swap panel: Schritt 7, Bild 1 von 1
    • At this point, the LCD is removed, and the new one can be attached.
    • From this point forward in the instructions, you will need to pretty much work backwards.
    • I made notes to make it a bit easier.
    • Remember the little triangle markers when attaching the frame to the back.
  8. HP EliteBook 8440p LCD Replacement, Add new adhessive: Schritt 8, Bild 1 von 3 HP EliteBook 8440p LCD Replacement, Add new adhessive: Schritt 8, Bild 2 von 3 HP EliteBook 8440p LCD Replacement, Add new adhessive: Schritt 8, Bild 3 von 3
    • Apply new adhesive to the back of the LCD face (otherwise there will be a little rattle).
    • I used standard double-sided tape.
    • I folded it lengthwise to thicken it, and trimmed with a razor.
    • If you look closely, you will see light markings where the tape should be applied.
    • (sorry about this last photo,iFixit makes the crop 4:3, which cuts off the image... Ill try to replace next time I replace one.)
  9. HP EliteBook 8440p LCD Replacement, Reattach Face: Schritt 9, Bild 1 von 3 HP EliteBook 8440p LCD Replacement, Reattach Face: Schritt 9, Bild 2 von 3 HP EliteBook 8440p LCD Replacement, Reattach Face: Schritt 9, Bild 3 von 3
    • To put the face back on, open the screen up all the way up.
    • Place the face gently in place, use the light and knobs on the top to reference the placing.
    • Start at the hp logo, and push down firmly, and slide out the the edges.
    • Do each side separately, starting at the bottom, and working up.
  10. HP EliteBook 8440p LCD Replacement, Screw in face to LCD screen: Schritt 10, Bild 1 von 1
    • Screw in the four corner PH0 screws
  11. HP EliteBook 8440p LCD Replacement, Reattach rubber pads: Schritt 11, Bild 1 von 1
    • Reattach the four screw covers / rubber pads.
    • You can use small pieces of double-stick tape.
Abschluss
To reassemble your device, follow these instructions in reverse order. Steps 8-11 are reassembly notes.
11 weitere Nutzer:innen haben diese Anleitung absolviert.
Eric D
1.284 Reputation
5 Anleitungen geschrieben
4 Kommentare
Good guide, I used it to replace an LCD on a HP EliteBook 8540p.
The only difference between those two models for replaceling the screen is that there are 6 rubber pads need to be removed (and thus 6 screws under the pads) (the two rubber pads at the top center you need to remove to).
Yannick Peeters - Antwort
hi i am anas from india
my laptop screen is damage today
can you help me how can i purchase it in low cost of lcd
because there price is too high and it is not genuine price
my email :anas.malik3377@gmail.com
mobile no +919210744541
anas malik - Antwort
modle is hp elitebook 8440p
Excellent guide! I used it to replace the screen on my 8440p; everything went according to the instructions, it took me about 35 mins. or so.
Robert Old - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 16
Insgesamt: 9,726
