Zum Hauptinhalt wechseln
HP EliteBook 8530w Battery Replacement
  1. HP EliteBook 8530w Battery Replacement, Battery: Schritt 1, Bild 1 von 2 HP EliteBook 8530w Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the laptop off then place it down so that the back is facing up.
    • Slide the battery release switch to the left and hold it there.
  2. HP EliteBook 8530w Battery Replacement: Schritt 2, Bild 1 von 2 HP EliteBook 8530w Battery Replacement: Schritt 2, Bild 2 von 2
    • Pull the battery away upward and away from the laptop while continuing to hold the release switch.
    • Once the battery is removed from the laptop, you may release the switch.
    • To properly dispose of your battery, look for the closest location that accepts electronic waste in your area and drop it off there.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 528
