Einleitung
If your device is frequently overheating or making excessive noise, especially during compute intensive tasks, it may be due to a malfunctioning or dirty fan. This guide will show you how to replace the fan in the HP EliteBook 8530w laptop in the hopes of alleviating these issues.
Was du brauchst
Turn the laptop off then place it down so that the back is facing up.
Slide the battery release switch to the left and hold it there.
Pull the battery away upward and away from the laptop while continuing to hold the release switch.
Unscrew the two screws from the center panel with a Phillips #00 screwdriver.
Flip the laptop over then open the lid.
Slide the four tabs at the top of the keyboard towards you with your finger.
Wedge a finger or spudger in the top corner of the keyboard and hinge it forward to reveal the backside.
Use a Torx TR7 screwdriver to remove the three screws holding down the fan.
Gently remove the fan connector that plugs into the motherboard.
Remove the fan.
Eine weitere Person hat diese Anleitung absolviert.
