Zum Hauptinhalt wechseln
HP EliteBook 8530w Fan Replacement
Was du brauchst
  1. HP EliteBook 8530w Fan Replacement, Battery: Schritt 1, Bild 1 von 2 HP EliteBook 8530w Fan Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the laptop off then place it down so that the back is facing up.
    • Slide the battery release switch to the left and hold it there.
  2. HP EliteBook 8530w Fan Replacement: Schritt 2, Bild 1 von 2 HP EliteBook 8530w Fan Replacement: Schritt 2, Bild 2 von 2
    • Pull the battery away upward and away from the laptop while continuing to hold the release switch.
    • Once the battery is removed from the laptop, you may release the switch.
    • To properly dispose of your battery, look for the closest location that accepts electronic waste in your area and drop it off there.
  3. HP EliteBook 8530w Fan Replacement, Fan: Schritt 3, Bild 1 von 1
    • Unscrew the two screws from the center panel with a Phillips #00 screwdriver.
    • These screws should have a keyboard icon stamped next to them.
  4. HP EliteBook 8530w Fan Replacement: Schritt 4, Bild 1 von 3 HP EliteBook 8530w Fan Replacement: Schritt 4, Bild 2 von 3 HP EliteBook 8530w Fan Replacement: Schritt 4, Bild 3 von 3
    • Flip the laptop over then open the lid.
    • Slide the four tabs at the top of the keyboard towards you with your finger.
    • Wedge a finger or spudger in the top corner of the keyboard and hinge it forward to reveal the backside.
    • Do not try to pull the keyboard out of the laptop. There are still cables connected to it that can easily be damaged.
  5. HP EliteBook 8530w Fan Replacement: Schritt 5, Bild 1 von 3 HP EliteBook 8530w Fan Replacement: Schritt 5, Bild 2 von 3 HP EliteBook 8530w Fan Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use a Torx TR7 screwdriver to remove the three screws holding down the fan.
    • Gently remove the fan connector that plugs into the motherboard.
    • Note: It can help to use something like tweezers to remove the connector if you are having trouble.
    • Remove the fan.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 18
Insgesamt: 683
