Zum Hauptinhalt wechseln
HP EliteBook 8530w Screen Replacement
Was du brauchst
  1. HP EliteBook 8530w Screen Replacement, Battery: Schritt 1, Bild 1 von 2 HP EliteBook 8530w Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the laptop off then place it down so that the back is facing up.
    • Slide the battery release switch to the left and hold it there.
  2. HP EliteBook 8530w Screen Replacement: Schritt 2, Bild 1 von 2 HP EliteBook 8530w Screen Replacement: Schritt 2, Bild 2 von 2
    • Pull the battery away upward and away from the laptop while continuing to hold the release switch.
    • Once the battery is removed from the laptop, you may release the switch.
    • To properly dispose of your battery, look for the closest location that accepts electronic waste in your area and drop it off there.
  3. HP EliteBook 8530w Screen Replacement, Screen: Schritt 3, Bild 1 von 1
    • Turn the laptop off then place it down so that the top is facing up, then open the laptop.
    • Remove the six screws around the screen bezel using a Phillips #00 screwdriver.
  4. HP EliteBook 8530w Screen Replacement: Schritt 4, Bild 1 von 3 HP EliteBook 8530w Screen Replacement: Schritt 4, Bild 2 von 3 HP EliteBook 8530w Screen Replacement: Schritt 4, Bild 3 von 3
    • Using a plastic opening tool, gently pry the bezel from the screen on all four sides.
    • Remove the bezel.
  5. HP EliteBook 8530w Screen Replacement: Schritt 5, Bild 1 von 3 HP EliteBook 8530w Screen Replacement: Schritt 5, Bild 2 von 3 HP EliteBook 8530w Screen Replacement: Schritt 5, Bild 3 von 3
    • Lift the screen from the frame at the top of the laptop.
    • At the bottom of the screen, there will be a cable connected to the body of the laptop. Remove this cable.
    • On the back of the screen, there will be a ribbon cable that connects to it. Remove this cable by pinching the two tabs on the ends of the connector and pull outwards.
  6. HP EliteBook 8530w Screen Replacement: Schritt 6, Bild 1 von 3 HP EliteBook 8530w Screen Replacement: Schritt 6, Bild 2 von 3 HP EliteBook 8530w Screen Replacement: Schritt 6, Bild 3 von 3
    • The screen is being held in place by eight screws on the left and right side. Remove these eight screws with a Phillips #00 screwdriver.
    • These screws are the only thing holding the screen in place. Make sure you are holding the screen when you are removing the last few screws.
    • Remove the screen.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
2 Kommentare
Hi! I have this laptop and i got a problem. Laptop starts but it's not showing nothing on the screen. If i remove the RAM memory i cannot here any sound from the motherboard so i think that the problem it is not in the screen and it's on the motherboard. What kind of test i could make to check my theory? Could be the BIOS too? Any help pls
Alvaro ConecTaller - Antwort
Hi I have a similar laptop, the 8540w that I want to keep working with it's DreamColor screen, but the plastic tabs on the flat ribbon cable connector fell apart. Do you recommend using a solder iron to remove and then replace the connector or could a non-conductive polymide tape work to hold the ribbon in place? It's disappointing that plastic deteriorates, otherwise, it's a functional laptop.
Ros - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 11
Insgesamt: 716
