Zum Hauptinhalt wechseln
HP EliteBook 8560w Back Panel Replacement
Was du brauchst
  1. HP EliteBook 8560w Back Panel Replacement, Battery: Schritt 1, Bild 1 von 2 HP EliteBook 8560w Back Panel Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w Back Panel Replacement: Schritt 2, Bild 1 von 1
    • Pull the battery out.
  3. HP EliteBook 8560w Back Panel Replacement, Back Panel: Schritt 3, Bild 1 von 2 HP EliteBook 8560w Back Panel Replacement, Back Panel: Schritt 3, Bild 2 von 2
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w Back Panel Replacement: Schritt 4, Bild 1 von 1
    • Slide the panel towards you and lift it up to open and access the back of the computer.
Ziellinie
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 20
Letzte 30 Tage: 34
Insgesamt: 1,637
