Zum Hauptinhalt wechseln
HP EliteBook Folio 1020 G1 Motherboard Replacement
Was du brauchst
  1. Achtung: Die Schritte 1-2 stammen von einer Anleitung, die derzeit bearbeitet wird.
    HP EliteBook Folio 1020 G1 Motherboard Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Use a TR8 Torx screwdriver to remove:
    • Six 5.3 mm screws
    • Four 3.3 mm screws
  2. HP EliteBook Folio 1020 G1 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Use a nylon spudger to gently pry the lower case up and off.
  3. HP EliteBook Folio 1020 G1 Motherboard Replacement, Battery: Schritt 3, Bild 1 von 2 HP EliteBook Folio 1020 G1 Motherboard Replacement, Battery: Schritt 3, Bild 2 von 2
    • Gently pull and free the battery's bundled cable connector that leads from the battery to the motherboard.
  4. HP EliteBook Folio 1020 G1 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #1 screwdriver to unscrew and remove the six 4 mm screws that secure the battery.
  5. HP EliteBook Folio 1020 G1 Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 2 HP EliteBook Folio 1020 G1 Motherboard Replacement, Motherboard: Schritt 5, Bild 2 von 2
    • Remove:
    • Eight 4.6 mm screws shown in the circles using Phillips #0.
  6. HP EliteBook Folio 1020 G1 Motherboard Replacement: Schritt 6, Bild 1 von 3 HP EliteBook Folio 1020 G1 Motherboard Replacement: Schritt 6, Bild 2 von 3 HP EliteBook Folio 1020 G1 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Disconnect the keyboard connections from the motherboard.
    • Disconnect by lifting the underside of the white tabs with a spudger.
  7. HP EliteBook Folio 1020 G1 Motherboard Replacement: Schritt 7, Bild 1 von 3 HP EliteBook Folio 1020 G1 Motherboard Replacement: Schritt 7, Bild 2 von 3 HP EliteBook Folio 1020 G1 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Disconnect circled terminals. Disconnect by lifting the underside of white tabs with spudger.
  8. HP EliteBook Folio 1020 G1 Motherboard Replacement: Schritt 8, Bild 1 von 3 HP EliteBook Folio 1020 G1 Motherboard Replacement: Schritt 8, Bild 2 von 3 HP EliteBook Folio 1020 G1 Motherboard Replacement: Schritt 8, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the circled tabs by pulling on the white support edges backward with a pair of tweezers.
  9. HP EliteBook Folio 1020 G1 Motherboard Replacement: Schritt 9, Bild 1 von 3 HP EliteBook Folio 1020 G1 Motherboard Replacement: Schritt 9, Bild 2 von 3 HP EliteBook Folio 1020 G1 Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Gently pull on the black pull tab on the top of the connector.
    • For the wires going to the Wi-fi card, remove both wires going to the top of the card using the tweezers.
  10. HP EliteBook Folio 1020 G1 Motherboard Replacement: Schritt 10, Bild 1 von 2 HP EliteBook Folio 1020 G1 Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Lift the now disconnected motherboard from the side shown in image 1. This side must be lifted to not damage the ports. The disconnected motherboard (aside from port removed in step 12) is shown in image 2.
Abschluss
Attach terminals in reverse order of guide to new motherboard, reattach the battery and back panel.
IUPUI, Team 2-1, Harley Spring 2023 Mitglied von IUPUI, Team 2-1, Harley Spring 2023
IUPUI-HARLEY-S23S2G1
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 189
