Einleitung
This guide is intended to illustrate the process of removing a motherboard from an HP Elitebook Folio 1020 G1 so that it can be replaced.
Before taking any part of the computer apart, please remember to power down your computer and unplug the power cable from any power source. Failure to do so could harm yourself or the computer, so these precautions must be taken.
Was du brauchst
Schritt 1 Lower Case
Achtung: Die Schritte 1-2 stammen von einer Anleitung, die derzeit bearbeitet wird.
Use a TR8 Torx screwdriver to remove:
Six 5.3 mm screws
Four 3.3 mm screws
Gently pull and free the battery's bundled cable connector that leads from the battery to the motherboard.
Use a Phillips #1 screwdriver to unscrew and remove the six 4 mm screws that secure the battery.
Remove:
Eight 4.6 mm screws shown in the circles using Phillips #0.
Disconnect circled terminals. Disconnect by lifting the underside of white tabs with spudger.
Remove the circled tabs by pulling on the white support edges backward with a pair of tweezers.
Gently pull on the black pull tab on the top of the connector.
For the wires going to the Wi-fi card, remove both wires going to the top of the card using the tweezers.
Lift the now disconnected motherboard from the side shown in image 1. This side must be lifted to not damage the ports. The disconnected motherboard (aside from port removed in step 12) is shown in image 2.
Attach terminals in reverse order of guide to new motherboard, reattach the battery and back panel.
