Einleitung
Is your trackpad enabled yet not responding? If so, this is a guide to fix the problem by replacing the trackpad in your HP EliteBook Folio 1020 G1.
Please remember to power down your computer and unplug it to avoid any power surges or shorts. Failing to power down and disconnect the power cable may result in further harm to the laptop or even yourself, so precautions must be taken.
Was du brauchst
Schritt 1 Lower Case
Achtung: Die Schritte 1-2 stammen von einer Anleitung, die derzeit bearbeitet wird.
Use a TR8 Torx screwdriver to remove:
Six 5.3 mm screws
Four 3.3 mm screws
Unplug the white bundled cable connector that leads from the battery to the motherboard.
Use a Phillips #1 screwdriver to unscrew and remove the six 4 mm screws that secure the battery.
The trackpad is connected to the motherboard via a small ribbon cable. Lift the black tab on the ZIF cable connector, and gently pull the ribbon cable free.
Use a Phillips #1 screwdriver to unscrew and remove the four 2 mm screws that secure the trackpad.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
