Zum Hauptinhalt wechseln
HP EliteBook x360 1030 G3 WWAN Card Replacement
Was du brauchst
    1. HP EliteBook x360 1030 G3 WWAN Card Replacement, Bottom Cover: Schritt 1, Bild 1 von 1
      • Be sure to power off and unplug your device before you begin your repair.
      • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
      • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
      • Remove the remaining four 7.3 mm screws using the same screwdriver.
      Frag FixBot
      Kommentar hinzufügen
    2. HP EliteBook x360 1030 G3 WWAN Card Replacement: Schritt 2, Bild 1 von 1
      • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
      • The plastic fastening may make cracking sounds when separating, but this is normal.
      Frag FixBot
    1. HP EliteBook x360 1030 G3 WWAN Card Replacement, WWAN Card: Schritt 3, Bild 1 von 2 HP EliteBook x360 1030 G3 WWAN Card Replacement, WWAN Card: Schritt 3, Bild 2 von 2
      • Detach the small wires connected to the card by lifting the ends straight upward. The wires are held in place by friction and should pop right off.
      • These wires should be handled carefully since they're the mobile cell service/WWAN antennas.
      • Take note of which wire goes where, as mixing these cables will cause the mobile cell service/WWAN to stop working.
      Frag FixBot
    2. HP EliteBook x360 1030 G3 WWAN Card Replacement: Schritt 4, Bild 1 von 1
      • Remove the 2.4 mm screw holding the card down using a Phillips #00 screwdriver.
      Frag FixBot
    3. HP EliteBook x360 1030 G3 WWAN Card Replacement: Schritt 5, Bild 1 von 2 HP EliteBook x360 1030 G3 WWAN Card Replacement: Schritt 5, Bild 2 von 2
      • Carefully pull out the card by sliding it to the left.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team S2-G9, Maness Spring 2019 Mitglied von Cal Poly, Team S2-G9, Maness Spring 2019
CPSU-MANESS-S19S2G9
4 Mitglieder
53 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 18
Letzte 30 Tage: 63
Insgesamt: 3,741
