Einleitung
This guide shows how to remove the wireless card from your laptop.
Was du brauchst
Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
Remove the remaining four 7.3 mm screws using the same screwdriver.
Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
Detach the small wires connected to the card by lifting the ends straight upward. The wires are held in place by friction and should pop right off.
Remove the 2.4 mm screw holding the card down using a Phillips #00 screwdriver.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
