Zum Hauptinhalt wechseln
HP EliteBook x360 830 G5 M2 Solid State Drive Replacement
Was du brauchst
  1. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • With the T5 screw-bit and screwdriver, loosen the five captive screws on the bottom of the laptop.
  2. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: Schritt 2, Bild 1 von 2 HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: Schritt 2, Bild 2 von 2
    • With a spudger or opening tool, pry above the computer's hinges and separate the posterior edge and sides.
  3. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: Schritt 3, Bild 1 von 1
    • The back cover is held in place by magnetic strips.
    • Remove the battery.
  4. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement, M.2 Solid State Drive: Schritt 4, Bild 1 von 1
    • Pull the tab attached to the M.2 solid state drive shield up.
  5. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: Schritt 5, Bild 1 von 1
    • With the Phillips #1 screwdriver, loosen the single screw that secures the M.2 solid state drive to the system board.
  6. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: Schritt 6, Bild 1 von 1
    • Once the springs release, carefully remove the M.2 solid state drive.
    • Pull the SSD card gently so you don't bend any pins.
Abschluss
Ashia Lewis
246 Reputation
2 Anleitungen geschrieben
University of Alabama, Team 1-4, Bedsole Fall 2021 Mitglied von University of Alabama, Team 1-4, Bedsole Fall 2021
UA-BEDSOLE-F21S1G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 16
Insgesamt: 521
