Zum Hauptinhalt wechseln
HP EliteBook x360 830 G6 CMOS Battery Replacement
Was du brauchst
  1. HP EliteBook x360 830 G6 CMOS Battery Replacement, Unfasten the back cover: Schritt 1, Bild 1 von 1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 CMOS Battery Replacement, Release the clips: Schritt 2, Bild 1 von 2 HP EliteBook x360 830 G6 CMOS Battery Replacement, Release the clips: Schritt 2, Bild 2 von 2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 CMOS Battery Replacement, Release the remaining clips: Schritt 3, Bild 1 von 2 HP EliteBook x360 830 G6 CMOS Battery Replacement, Release the remaining clips: Schritt 3, Bild 2 von 2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 CMOS Battery Replacement, Remove the back cover: Schritt 4, Bild 1 von 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, Remove the back cover: Schritt 4, Bild 2 von 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, Remove the back cover: Schritt 4, Bild 3 von 3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 CMOS Battery Replacement, Disconnect the battery: Schritt 5, Bild 1 von 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, Disconnect the battery: Schritt 5, Bild 2 von 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, Disconnect the battery: Schritt 5, Bild 3 von 3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 CMOS Battery Replacement, CMOS Battery: Schritt 6, Bild 1 von 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, CMOS Battery: Schritt 6, Bild 2 von 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, CMOS Battery: Schritt 6, Bild 3 von 3
    • Use your fingers or the pointed end of a spudger disconnect the CMOS battery connector.
  7. HP EliteBook x360 830 G6 CMOS Battery Replacement: Schritt 7, Bild 1 von 1
    • Remove the CMOS battery from its housing by pulling up the small, black plastic tab that is holding it in place.
Abschluss
Brody Reder
301 Reputation
3 Anleitungen geschrieben
IUPUI, Team 3-3, Harley Spring 2024 Mitglied von IUPUI, Team 3-3, Harley Spring 2024
IUPUI-HARLEY-S24S3G3
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 16
Letzte 30 Tage: 77
Insgesamt: 106
